What You Should Know Before Deploying in CoD Modern Warfare 4 DMZ?
Ephraim
Сообщение Ephraim »
As a distinctive open-world extraction mode in CoD: Modern Warfare 4, DMZ differs significantly from traditional multiplayer combat. Players must drop into a high-risk warzone, scavenge for supplies, and complete contract objectives; only by successfully reaching an extraction point can they retain the loot they have gathered.
If a player dies during the match, all weapons, armor, and mission items in their backpack are lost. Newcomers often overlook the mode's fundamental rules, leading to frequent failures after hasty deployments. Before launching any mission, every player should familiarize themselves with the following key points.
Basic Deployment Rules and Risk Mechanics
The core concept of DMZ is the balance between risk and reward. Before deploying, you must choose which "Insured Weapons" to bring; if you die, these weapons are not permanently lost but enter a cooldown period during which they cannot be used. Conversely, non-insured weapons are lost immediately upon death.
The map is populated by AI enemies, other player squads, and random event strongholds, with threat levels varying drastically across different zones.
Low-threat zones are ideal for beginners to learn the map, though the loot value is generally modest. High-threat strongholds contain high-tier loot but feature extremely tough AI and attract rival squads vying for control. Contracts - ranging from scavenging and assassination to escort missions - are the primary way to acquire high-value items; completing them unlocks additional extraction points, significantly boosting your chances of a successful exfil.
A common mistake beginners make is rushing straight into high-threat zones without preparing armor vests or self-revive kits, leaving no margin for error during firefights. To quickly master controls and reduce combat pressure, many players opt for CoD MW4 Bot Lobbies, practicing movement and weapon handling against weaker opponents without the constant frustration of high-intensity PvP.
Supplies, Contracts, and Extraction Strategies
Upon entering the map, prioritize gathering armor plates, medical kits, and ammunition rather than obsessively chasing high-tier weapons. Squad coordination is crucial in DMZ; solo play leaves very little room for error. When playing as a team, it is best to assign roles: one person for scouting, one to carry ample supplies, and one to lead the assault.
Extraction points fall into two categories: fixed locations and random helicopter extractions. Fixed extraction points are highly contested and often camped by other players looking to ambush; random extraction points appear after completing contracts, making them a better choice for squads seeking a safer exit. The extraction countdown is a high-risk period; many teams lie in wait near extraction points, launching surprise attacks only after other players have initiated the countdown.
Additionally, secret caches and locked rooms scattered across the map can yield rare weapon blueprints and cosmetic items; some items can even be exchanged for rewards outside of the match.
Key Tips to Avoid Pitfalls
Many players overlook the match time limit. DMZ matches have a fixed duration; failing to extract in time results in a mission failure and the loss of all your gear. Avoid endless looting and plan your extraction route in advance.
When engaging AI, be aware that they call for reinforcements; prolonged firefights attract endless waves of enemies, so try to resolve engagements quickly. If you encounter an enemy squad, assess the equipment gap; if you are at a disadvantage, prioritize bypassing them rather than forcing a fight.
Final Deployment Advice
Before dropping in, take a moment to plan your objective: whether it is simply gathering supplies, completing specific contracts, or unlocking weapon blueprints. Choose the appropriate zone based on your goal and stock up on supplies. Beginners should avoid rushing into high-difficulty strongholds; instead, familiarize yourself with the map and practice extraction procedures in low-threat areas to gradually build experience.
The joy of DMZ lies in the thrill of the unknown, but every deployment requires making strategic choices. By wisely utilizing resources and selecting the right environment for your playstyle, you can steadily gather loot, avoid common beginner pitfalls, and increase your extraction success rate with every deployment.
Вернуться в «Продам»
