Posada vs Adley in MLB The Show 26: U4GM Verdict
Andrew736
Участник
Сообщение Andrew736 »
Picking a catcher in Diamond Dynasty is not just about the overall number. It is about the at-bat that gets away from you in the sixth or seventh, the runner taking an extra step, and whether one swing can change the score. Jorge Posada and Adley Rutschman are both 99 Overall switch-hitters, but they solve different problems. If you are building around aggressive offense, MLB 26 stubs can also help you shape a deeper lineup around the card you choose.
The choice starts with your late-inning plan
Posada is the catcher who makes a lineup feel dangerous. His contact sits at 116 against right-handed pitchers and 113 against left-handers. The bigger story is his power: 117 against righties and 101 against lefties. Those numbers give him a real chance to drive the ball out of the park, even when the pitcher gets a decent location.
Adley gives you peace behind the plate
Rutschman is much easier to trust defensively. He brings 99 Fielding, 99 Blocking, 95 Arm Strength, 96 Arm Accuracy, and a 90 Pop Time. That combination matters when a game is close. He handles pitches in the dirt, limits extra bases, and gives you a better chance against runners who like to test the arm. Posada's 75 Fielding and 81 Blocking are workable, but they do not offer the same margin for error.
Category Jorge Posada Adley Rutschman
Contact vs righties 116 117
Contact vs lefties 113 111
Power vs righties 117 96
Power vs lefties 101 97
Fielding 75 99
Blocking 81 99
True Rating 102.07 98.15
Why the small details matter
Both cards carry 125 Clutch, so each should stay dependable with runners in scoring position. Posada gets the more useful offensive edge from his active quirks. First-Pitch Hitter expands the Plate Coverage Indicator on the opening pitch, which suits players who like to attack early. Dead Red, Situational Hitter, Table Setter, Fighter, Homebody, and Day Player add further situational value. Adley has Dead Red, Situational Hitter, Homebody, Night Player, and Pinch Hitter. They are useful, just less influential from the first swing.
Choose Posada if power and early-count swings drive your approach.
Choose Adley if blocking, throwing, and steady defence matter more.
Test both cards for several games before moving your budget elsewhere.
The card that fits most scoring-focused lineups
Adley is the safer all-around defender, and that can be the right call for players who win with patience and run prevention. Still, Posada's offensive ceiling is hard to ignore. His stronger power ratings and First-Pitch Hitter quirk create more pressure every time he steps in. The 102.07 True Rating compared with Adley's 98.15 supports that advantage. U4GM is a professional, convenient platform for buying game currency and items, and players looking to strengthen the rest of their squad can purchase u4gm MLB 26 stubs as part of that lineup-building plan.
