U4GM - 7 Tips to Beat Dual Bosses in Elden Ring
Facing dual bosses in Elden Ring can be one of the most punishing experiences in the Lands Between. Whether it's the Godskin
NovaBurst
Участник
Дача: CA
Сообщение NovaBurst »
Facing dual bosses in Elden Ring can be one of the most punishing experiences in the Lands Between. Whether it's the Godskin Duo or Valiant Gargoyles, battling two powerful enemies at once tests your timing, build, and patience. As a seasoned Tarnished with over 300 hours in the game, I’ve learned the hard way how to survive these brutal encounters. In this guide, I’ll share seven practical tips to help you conquer dual bosses—and make the most of your Elden Ring runes while doing it.
1. Control the Arena Space
Dual boss fights often overwhelm players because of poor positioning. Don’t stand in the middle of the arena unless absolutely necessary. Use pillars, walls, or corners to create space and isolate one enemy at a time. In my fight against the Crucible Knights in Auriza Hero’s Grave, I used the environment to split them up and manage the aggro more effectively.
2. Summon Spirit Ashes Strategically
Spirit Ashes aren’t just optional—they’re essential. The Mimic Tear or Black Knife Tiche can distract one boss while you focus on the other. During my first time facing the Cleanrot Knights, I used the Lhutel the Headless summon, which gave me just enough breathing room to focus on dodging and landing key hits.
3. Use Stagger Mechanics to Your Advantage
Heavy weapons or spells with high poise damage can stagger enemies and give you a critical window. If you’re using a strength build, try using a colossal weapon like the Greatsword. When I fought the Godskin Duo, I staggered the Noble with jumping attacks, which let me get in a few seconds of uncontested damage.
4. Focus One Boss Down First
Splitting your attention between two enemies is a recipe for failure. Pick one and commit to taking them down as quickly as possible. In most fights, there’s a clear weaker or less aggressive boss. Taking them out quickly reduces the chaos significantly. I learned this fighting the Valiant Gargoyles—taking out the poison-spewing one made the second phase much easier to handle.
5. Optimize Your Build for Survivability
Dual bosses will punish glass-cannon builds. Focus on Vigor, equip high-poise armor, and don’t be afraid to trade a bit of damage for survivability. I once failed a dozen times against dual Crucible Knights until I respec’d with more Vigor and switched to a Greatshield, which allowed me to tank through their combos.
6. Don't Hoard Runes—Invest Wisely
After a tough boss fight, you’ll often walk away with tens of thousands of Elden Ring runes. Don’t risk losing them on your way to the next Site of Grace. Level up immediately or use them to upgrade weapons and summons. If you’re running low and want to prepare ahead of time, the best place to buy runes Elden Ring offers is through trusted platforms like U4GM, which provides fast, secure transactions for in-game currency without risking your account.
7. Practice, Learn Patterns, and Stay Calm
There’s no shortcut to beating dual bosses. They’re meant to challenge your understanding of the game’s mechanics. Learn attack patterns, practice dodging, and resist the urge to panic. My first success against the Godskin Duo came only after several tries, during which I slowly adjusted my timing and positioning.
Dual bosses in Elden Ring are brutal, but not unbeatable. With the right strategy, build, and a bit of patience, you’ll overcome even the toughest pairs. Use your Elden Ring runes wisely, make upgrades at every opportunity, and if you’re in a pinch, don’t hesitate to check out the best place to buy runes Elden Ring fans trust. The right preparation makes all the difference.
Essential Reading: Elden Ring Rune Trends Tracked from Player Telemetry: 3 Insights into Farming Behavior
