Diablo 4 Season 15 Power-Leveling Routes at U4GM
Andrew736
Участник
Сообщение Andrew736 »
Season 15, known as Season of Hell's Legacy, changes the opening hours of Diablo 4 quite a bit. With Patch 3.2.1 arriving on September 15, 2026, players can reach level 70 far sooner than expected if they use the new seasonal systems properly. The return of Diablo, Baal, and Mephisto adds plenty of excitement, but the early priority is simple: build momentum. A few useful D4 items can also smooth out the first few fights while your seasonal setup comes together.
Make the Command Table Your First Stop
Do not rush into random activities after creating your character. Visit the Horadric Cube first, take the early level, and speak with Tyrael. This unlocks the War Plans Command Table, which should guide the rest of the opening session. Reroll the available plans until Helltide choices appear, then work towards Writhe and Rot. That keystone is the key to the quickest route because it changes how Hellwyrms appear during Helltides. Reaching level 25 is also a sensible target for players who prefer a more controlled pace, since Kurast Undercity becomes much stronger from that point onward.
Move to Kurast When the Timing Is Right
Jade Epiphany gives the Kurast Undercity route its real value. Before unlocking it, run directly towards the end of the activity and ignore most enemies. The aim is to finish quickly and collect enough War Plan progress. Once the node is active, chase Attunement rather than kills. Each new rank creates experience orbs near your character, and Rank 4 should be reached as quickly as possible. Pick up those orbs yourself; pets do not gather them automatically. Then enter the boss room, finish the encounter, and reset the Undercity.
Keep the Helltide Loop Clean
For a level 1 start, Helltides remain the quickest option when the table offers the right plans. Raise Threat Level until the final section, then watch for Hellwyrms. They release Plague Maggot Young, and those creatures provide the experience that makes this route so quick. Stop attacking ordinary enemies once the worms arrive. Filling the meter too far can trigger a champion, reset progress, and interrupt the flow. When you are ready to open chests or hand in Aberrant Cinders, briefly changing to Penitent can improve the reward without forcing you to fight every tougher creature.
Keep moving between worm locations instead of clearing the whole zone.
Collect experience orbs manually during Undercity runs.
Use regional route maps for Kehjistan and Scosglen if you are learning the spawn pattern.
Choose Speed or Long-Term Value
The fastest players can combine Helltide runs with the Undercity loop and reach level 70 in about an hour. That approach suits a fresh seasonal character with one clear goal. If you would rather prepare for Torment content as you level, rotate through Helltides, Infernal Hordes, Tree of Whispers tasks, and Kurast. It may take closer to ninety minutes, but you will gain crafting materials, Legacy Uniques, and useful resources along the way. This broader route feels less repetitive and leaves your character in a healthier position for Masterworking and Mythic crafting, especially when you choose to buy cheap D4 items before tackling the Prime Evils.
